iPad activations
  • 1.  iPad activations
    Posted Mar 29, 2013 05:56 PM
    I was wondering how others are handling the activation of iPads out of the box on their wireless networks.  iPad reach out to Apple.com before futures are functional if I am correct.  A login splash page such as a captive portal breaks this activation.  Do you request that users activate their new iPads from home networks, over a mifi network or cellular before access a guest network in your corporation?  Just wondering others handle the avalanche of devices.
  • 2.  RE: iPad activations
    Posted Mar 29, 2013 11:09 PM
    There are a couple of options.
    One is to setup a netdestination with the sites/domain names in question.  Then to add a rule to the Captive Portal policy to permit traffic to this netdestination/alias; placing the rule above the Captive Portal redirects.
    Example:
    (config)# netdestination allowed-ipad-sites
    (config-dest)# name apple.com
    (config)# ip access-list session <yourCPpolicy>
    (config-sess-<yourCPpolicy>)# user alias allowed-ipad-sites any permit position 1
    ***this rule needs to be before any DST-NAT entries
    A second option is to add a netdestination to the whitelist of the Captive Portal profile.
    Example:
    (config)# aaa authentication captive-portal <yourCPprofile>
    (Captive Portal Authentication Profile <yourCPprofile>)#white-list allowed-ipad-sites
  • 3.  RE: iPad activations
    Posted Apr 01, 2013 09:41 AM
    Thanks very much for the info.  I will give that a try.  To expand on that.  Is there a similar process if for the AmigoPod self-registration Guest portal?
  • 4.  RE: iPad activations
    Posted Apr 01, 2013 09:49 AM
    When you say similar process, do you mean to allow access to the guest registration portal without having the traffic hit the DST-NAT rule?   If so, you really have the same options really.   You can create a Network Destination that corresponds to your Amigopod or you can just add a line in your logon role to allow http/https traffic to Amigopod.
    (config)# ip access-list session <yourLogonRolepolicy>
    (config-sess-<yourLogonRolepolicy>)# user host <ip.of.amigopod> svc-http permit position 1
    (config-sess-<yourLogonRolepolicy>)# user host <ip.of.amigopod> svc-https permit position 2
    As part of a Network Destination:
    (config)# netdestination amigopod-servers
    (config-dest)# host <ip.of.amigopod>
    (config-sess-<yourLogonRolepolicy>)# user alias amigopod-servers svc-http permit position 1
    (config-sess-<yourLogonRolepolicy>)# user alias amigopod-servers svc-https permit position 2
