last person joined: 5 hours ago
Iphone 7 users droping signal
  • 1.  Iphone 7 users droping signal
    Posted Sep 05, 2019 05:03 AM
    We have some iphone 7 users who are experiencing problems with wifi connection. We have two different types of APs: AP-303 and AP-365. AP-365 sitts on the warehouse and next to the warehouse are the officess which AP-303 resides. Users with iphone 10 does not experience this problem, there are only iphone 7 users. Does anyone had this issue before? Can this be related to the AP models? Are there any settings on aruba central that can help to solve this issue!
    Thanks in advance
  • 2.  RE: Iphone 7 users droping signal
    Posted Sep 05, 2019 05:15 AM
    Does it always occur in the same place?  Did you use an iphone 7 to measure the signal in the area with the drops?
  • 3.  RE: Iphone 7 users droping signal
    Posted Sep 05, 2019 06:37 AM
    Yes, it does occur always on the same area! Do you think this has to do anything with fast roaming or client match or anything like that that can be tweaked on the central?
  • 4.  RE: Iphone 7 users droping signal
    Posted Sep 05, 2019 06:40 AM
    Make sure you have good coverage in that area.  If it is because of fast roaming, it should occur in other areas, as well.
  • 5.  RE: Iphone 7 users droping signal
    Posted Sep 05, 2019 06:43 AM
    I did measure the coverage with ekahau and it look all green! Iphone 10 users does not have the same problem! Only those with iphone7! It looks like more of a compatibility issue and I am stuck here!
  • 6.  RE: Iphone 7 users droping signal
    Posted Sep 05, 2019 06:45 AM
    Are you using encryption?
    Are you using both bands?
    What options are enabled for that SSID?
  • 7.  RE: Iphone 7 users droping signal
    Posted Sep 05, 2019 07:04 AM
    We are using WPA-2 Personal key management. We are using both bands. 11ac and 11ax are enabled.
    802.11r, 802.11k and 802.11v are also enabled. MDID is set to 65001 (I dont have any clue about this what this might be).
  • 8.  RE: Iphone 7 users droping signal
    Posted Sep 05, 2019 07:20 AM
    Try disalbing 802.11r as a test, so we can isolate the issue.
