Iphone and IPAD intermitently disconnects with wireless
  • 1.  Iphone and IPAD intermitently disconnects with wireless
    Posted Oct 03, 2017 12:52 AM
    Hi all friend and expert !
    I have some confused issues:
    I used IAP 325 and controller 7205
    All of my devices are running well, except iphone/ipad/IOS (apple devices), I met some following phenomena:
    After connected, it already got IP from DHCP server, but it disconnected and then reconnected.
    All of my laptop window, android still run well
    Please give me some ideas to troubleshooting this issue
    Thank you so much
    Lee nguen
  • 2.  RE: Iphone and IPAD intermitently disconnects with wireless
    Posted Oct 03, 2017 06:00 AM
    What version of IOS are these devices running?
  • 3.  RE: Iphone and IPAD intermitently disconnects with wireless
    Posted Oct 03, 2017 01:38 PM
    Dear Conlin
    My version is 10.3.3 (iPhone), when i access to Aruba WLAN, it alway connected => Disconnect=> Connecting
    I can confirm my phone working well at home, and ruckus. If you want me share my configuration, please tell me.
    Thank you so much
    LEe
  • 4.  RE: Iphone and IPAD intermitently disconnects with wireless
    Posted Oct 03, 2017 08:09 PM
    What kind of encryption do you have on that WLAN?
    Please make sure you don't have 802.11r, k or v enabled on that SSID.
    UPDATE 6/2018 -  The updated RF and Roaming Optimization Validated Reference Design Guide (VRD) has been published and has updated recommendations about enabling 802.11v, k and r in user networks.  The VRD can be found here: http://community.arubanetworks.com/t5/Validated-Reference-Design/RF-and-Roaming-Optimization-for-Aruba-802-11ac-Networks/ta-p/432994
  • 5.  RE: Iphone and IPAD intermitently disconnects with wireless
    Posted Oct 03, 2017 10:02 PM
    Dear Colin,
    For encryption im using:
    Mix mode : WPA-AES,WPA-TKIP,WPA2-AWS
    For authentication im using:802.1X via Cisco ACS (EAP)
    Already disable : 802.11r,k and v
    Thank you so much
    Lee
  • 6.  RE: Iphone and IPAD intermitently disconnects with wireless
    Posted Oct 04, 2017 07:30 AM
    You should not be using WPA-AES or WPA-TKIP.  WPA-AES is insecure and WPA-TKIP is also insecure, but forces the client association rate to be 54 megs or less.  In addition, some clients have problems with a mixed-encryption SSID.  You should standardize on WPA2-AES which provides the best speed and security.  To find out what clients could be using WPA-AES or WPA-TKIP, you should use the command:
    show dot1x supplicant-info list-all
     That will tell you how many of your clients are using WPA-AES or WPA-TKIP that you need to reconfigure to match WPA2-AES.
  • 7.  RE: Iphone and IPAD intermitently disconnects with wireless
    Posted Oct 04, 2017 12:19 PM
    Dear Colin,
    Thank for your advices
    I was change authentication/ encryption = wap2/aes, but iphone/ipad , OSX cannot acess smoothly, it connected and disconnect.
    Idont know why, my iphone working fine with ruckus and wifi at home but very difficult acess to aruba system.
    Thank you so much Colin
  • 8.  RE: Iphone and IPAD intermitently disconnects with wireless
    Posted Oct 05, 2017 03:07 AM
    Dear Colin, and all
    My topology
    Master
    Local
    master and local different geography.
    I have just deloyed in a new building, all the users here will be connected in controller local.
    According to my understandings, user connecting into WLAN will be authenticated on Local controller.
    But when I check log access on Radius sever (ACS), it is always authenticated by controller master.
    I didn’t find any user authenticated on Local at all. However, I still see user list of new buildings connecting into WLAN on local controller.
    Please give me some advices
    Thank you so much
    Lee
  • 9.  RE: Iphone and IPAD intermitently disconnects with wireless
    Posted Oct 05, 2017 03:11 AM
    I think that is one of rootcause, with apply devides im facing
    Thank you
