iPhone gets disconnected from SSID
  • 1.  iPhone gets disconnected from SSID
    Posted Jun 29, 2016 10:13 AM
    Hi
    I have a client connecting to a SSID using 802.1X authentication using an iPhone - the iAP is a 205.
    The user can connect with no problem, however a few minutes passes and he gets disconnected.
    From the AP I ran two commands "show ap debug auth-trace-buf <MAC>" whose output looks correct to me and I don't see any Radius errors for the authentication - so i will say that works correctly.
    When the disconnect happens I can see in the debug mgmt-frames there is a "Denied; Ageout"  message - I have no idea what it means and if it indicates a problem -- below is the output from the two commands.
    # show ap debug mgmt-frames e4:9a:79:bb:1e:91
    Traced 802.11 Management Frames
    Timestamp        stype       SA                 DA                 BSS                signal  Misc
    Jun 29 15:59:23  deauth      04:bd:88:95:b6:31  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31  15      - (internal only)
    Jun 29 15:51:10  assoc-resp  04:bd:88:95:b6:31  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31  15      Success
    Jun 29 15:51:10  assoc-req   e4:9a:79:bb:1e:91  04:bd:88:95:b6:31  04:bd:88:95:b6:31  0       -
    Jun 29 15:51:10  auth        04:bd:88:95:b6:31  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31  15      Success (seq num 0)
    Jun 29 15:51:10  auth        e4:9a:79:bb:1e:91  04:bd:88:95:b6:31  04:bd:88:95:b6:31  0       -
    Jun 29 15:50:49  deauth      04:bd:88:95:b6:31  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31  15      Denied; Ageout (seq num 0)
    Jun 29 15:50:49  assoc-resp  04:bd:88:95:b6:31  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31  15      Success
    Jun 29 15:50:49  assoc-req   e4:9a:79:bb:1e:91  04:bd:88:95:b6:31  04:bd:88:95:b6:31  0       -
    Jun 29 15:50:49  auth        04:bd:88:95:b6:31  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31  15      Success (seq num 0)
    Jun 29 15:50:49  auth        e4:9a:79:bb:1e:91  04:bd:88:95:b6:31  04:bd:88:95:b6:31  0       -
    # show ap debug auth-trace-buf e4:9a:79:bb:1e:91
    Auth Trace Buffer
    Jun 29 15:06:51  station-up             *  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            -   -     wpa2 aes
    Jun 29 15:06:51  eap-id-req            <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            1   5
    Jun 29 15:06:51  eap-id-resp           ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            1   13    Stantons
    Jun 29 15:06:51  rad-req               ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            31  180
    Jun 29 15:06:51  rad-resp              <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  31  -
    Jun 29 15:06:51  eap-req               <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            2   6
    Jun 29 15:06:51  eap-resp              ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            2   131
    Jun 29 15:06:51  rad-req               ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  32  316
    Jun 29 15:06:51  rad-resp              <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  32  -
    Jun 29 15:06:51  eap-req               <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            3   1024
    Jun 29 15:06:51  eap-resp              ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            3   6
    Jun 29 15:06:51  rad-req               ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  33  191
    Jun 29 15:06:51  rad-resp              <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  33  -
    Jun 29 15:06:51  eap-req               <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            4   1024
    Jun 29 15:06:51  eap-resp              ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            4   6
    Jun 29 15:06:51  rad-req               ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  34  191
    Jun 29 15:06:51  rad-resp              <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  34  -
    Jun 29 15:06:51  eap-req               <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            5   1024
    Jun 29 15:06:51  eap-resp              ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            5   6
    Jun 29 15:06:51  rad-req               ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  35  191
    Jun 29 15:06:51  rad-resp              <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  35  -
    Jun 29 15:06:51  eap-req               <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            6   273
    Jun 29 15:06:51  eap-resp              ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            6   336
    Jun 29 15:06:51  rad-req               ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  36  523
    Jun 29 15:06:51  rad-resp              <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  36  -
    Jun 29 15:06:51  eap-req               <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            7   69
    Jun 29 15:06:51  eap-resp              ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            7   63
    Jun 29 15:06:51  rad-req               ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  37  248
    Jun 29 15:06:51  rad-resp              <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  37  -
    Jun 29 15:06:51  eap-req               <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            8   95
    Jun 29 15:06:51  eap-resp              ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            8   127
    Jun 29 15:06:51  rad-req               ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  38  312
    Jun 29 15:06:51  rad-resp              <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  38  -
    Jun 29 15:06:51  eap-req               <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            9   111
    Jun 29 15:06:51  eap-resp              ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            9   63
    Jun 29 15:06:51  rad-req               ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  29  248
    Jun 29 15:06:51  rad-accept            <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31/t_DoleRAD  29  -
    Jun 29 15:06:51  eap-success           <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            9   4
    Jun 29 15:06:51  wpa2-key1             <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            -   117
    Jun 29 15:06:51  wpa2-key2             ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            -   117
    Jun 29 15:06:51  wpa2-key3             <-  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            -   151
    Jun 29 15:06:51  wpa2-key4             ->  e4:9a:79:bb:1e:91  04:bd:88:95:b6:31            -   95
    Does the Denied mnessage indicate a problem?
    Anything else to check and test to identify the problem?
  • 2.  RE: iPhone gets disconnected from SSID
    Posted Jun 30, 2016 02:31 AM
    Some aditional info I think is important -- the client has got a full signal as reported from the device. Airwave however is reporting the client health at 50%.
    From the iAP dashboard the specific AP is reporting a few other intefeering APs and a quite a few interfering clients for the AP itself -- I don't think it a problem though as my other clients connecte to the same AP aren't reporting any problems.
  • 3.  RE: iPhone gets disconnected from SSID
    Posted Jun 30, 2016 06:43 AM
    A client getting disconnected due to an ageout typically is the result of a timer expiring.
  • 4.  RE: iPhone gets disconnected from SSID
    Posted Jul 04, 2016 06:40 AM
    Hi Collin - thanks for pointing me in the right direction.
    The only limit I could find was "client inactivity" timer I set this from 1000 seconds (which matches the client complaint that they get disconnected after about 16 minutes) to 3 hours.
    So far I haven't recieved the complaint again.
