IPSec over Mesh
  • 1.  IPSec over Mesh
    Posted Mar 12, 2012 06:39 AM
    I have an Aruba Controller (SW: 6.1.2.7) and I have to build up a Mesh. This mesh is secured by WPA. My problem ist that the customer does not trust WPA.
    Is there a soulution to encapsulate the WPA-Traffic into an IPSec tunnel? I've readed about double-encryption but this is only a feature for RAPs.
    Marco
  • 2.  RE: IPSec over Mesh
    Posted Mar 12, 2012 10:34 AM
    Please note that Aruba OS MESH links are encrypted by WPA-2, not WPA.   A big difference... although neither is in danger of being practically breached at this point in time.
    Keep in mind that the WPA-2 we use on mesh links utilizes AES encryption (circa 1990's) which is ~20 years newer than the typical encryption type used by VPN clients (3DES...circa 1970's).    aka.   one is actually much 'safer' when using AES... aka the Mesh link encryption than a VPN client if one takes a step back to consider the underlying technologies in use.
    Hope that helps... ?
    JF
  • 3.  RE: IPSec over Mesh
    Posted Mar 16, 2012 08:14 AM
    thanks for your answer. Yes WPA2 is secure, I believe that :-)
    But the customer want's to have an IPSec-Tunnel in the WPA2-Tunnel because he dont trusts in WPA2.
    Is there a possibility?
    The solution should be
    RAP ------> MESH-Point --------------------------------> Meshportal ---------->LAN------------> Aruba
    In this sample the RAP will make an IPSec-Tunnel to the Controller. He uses the Mesh-Bridge so that ther is IPSec encapsulated in an WPA2.
    Is this solution possible without the RAP (with only 2 APs)?
    Marco
  • 4.  RE: IPSec over Mesh
    Posted Mar 16, 2012 08:48 AM
    @mawe wrote:
    Marco
    Marco, is this a wireless or wired client that will be connecting to the mesh point?
  • 5.  RE: IPSec over Mesh
    Posted Mar 19, 2012 04:12 AM
    there will be a switch which is connected to the Mesh-Point via LAN. The Mesh-Point is a single-radio-AP so that there will be no wireless connectivity for clients.
    Problem is that the customer dont wants to use VPN-Clients :-/
    All things should be done by the Controller.
