IPSEC/VPN address pool lease time
  • 1.  IPSEC/VPN address pool lease time
    Posted Mar 07, 2013 08:02 AM
    When an IP address is assigned from the address pool configured within VPN services how long is the lease time for that address?  For instance, if a VIA client connects pulls and address then the user disconnects when will that address be allocated back to the pool for assignment again?
  • 2.  RE: IPSEC/VPN address pool lease time
    Posted Mar 07, 2013 09:15 AM
    When a system disconnects from an L2TP VPN Pool, the IP will be aged out based upon 6 * the l2tp hello timer.   The hello timer is 60 seconds by default; so 6 minutes should be the ageout.
    To determine this in your environment:
    show vpdn l2tp configuration
    >Enabled
    >Hello timeout: 60 seconds
    To change your timer:
    config terminal
    vpdn group l2tp
    l2tp tunnel hello <timer>
