IPv6 on controller
  • 1.  IPv6 on controller
    Posted May 10, 2016 02:57 AM
    I already set ip address on vlan as Ipv6 (both link loacal and global address) and controller has 1 port which is connecting with switch.
    Port mode is access.
    Then I try to ping to Gateway on switch but It's fail.
    How I solve it ?
    Thank you
  • 2.  RE: IPv6 on controller
    Posted May 17, 2016 04:45 AM
    Not fully sure what your are looking for. The configuration on my controller looks like:
    ipv6 enable
    interface vlan 31
            ip address 192.168.31.2 255.255.255.0
            ipv6 address 2001:470:a154:31::2/64
            operstate up
    interface vlan 34
            ip address 192.168.34.2 255.255.255.0
            ipv6 address 2001:470:a154:34::2/64
            ip helper-address 192.168.32.22
            no suppress-arp
            operstate up
    ipv6 default-gateway 2001:470:a154:31::254
    Then, I can ping and show the IPv6 neighbor table like this:
    (Aruba7005) (config) #ping ipv6 2001:470:a154:31::254
    Press 'q' to abort.
    Sending 5, 92-byte ICMPv6 Echos to 2001:470:a154:31::254, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 2.564/2.9164/3.603 ms
    (Aruba7005) (config) #show ipv6 neighbors
    IPv6 Neighbors
    IPv6 Address                  Age  Link-layer Addr    State      Interface
    2001:470:a154:31:0:0:0:254  3    00:26:88:01:22:88  REACHABLE  vlan 31
    (Aruba7005) (config) #ping ipv6 2a00:1450:4009:811::200e
    Press 'q' to abort.
    Sending 5, 92-byte ICMPv6 Echos to 2a00:1450:4009:811::200e, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 15.974/16.2974/16.696 ms
    The last host (2a00:1450:4009:811::200e) is ipv6.google.com...
    If you configured IPv6, you should first see your default gateway in the 'show ipv6 neighbors' table...
    Till what point are you able to get??
  • 3.  RE: IPv6 on controller
    Posted May 17, 2016 09:58 PM
    I forgot a command "ipv6 enable". After that It's work !
    Thank you for reply
