The configuration seems ok, but keep in mind that IP address 192.168.53.201 on the Standby (Slot 2) switch won't be active when the switch joins the stack, because Master's 192.168.53.200 will take precedense. Also, after you save the configuration when the stack is joined, that 192.168.53.201 will disappear from the saved-configuration as well. In other words if this IP will exist only while the switch is standalone in sake of access to the switch during initial IRF configuation, it's fine. Otherwise Vlan-interface on all IRF members should have same configuration. Just FYI.
Also, there is one suggestion, just to develop correct skills - do not execute "irf-port-configuration activate' BEFORE you saved the config with IRF physical ports in 'undo shutdown' state. It's ok to do this if you plan to connect IRF cables afterwards, but many times we have to configure already cabled devices from remote, so this order of operations will lead to problems after Standby reboots. It's a little bit tricky, but if you do this:
Int range t2/0/15 to t2/0/16
Undo shutdown
Irf-port-configuration active
the Standby will reboot right away and many times it will do it BEFORE you will have a chance to execute 'save force' and as a result it will boot with Ten2/015;Ten2/0/16 in 'shutdown' state.
Therefore the good practice is to swap the order of commands and make it like this:
Undo shutdown
quit
save safely force
Important fact: "IRF port active" state is not saved in the 'saved-configuration', therefore it won't hurt if you activate IRF ports after saving the config.
Keep in mind that I give you example with IRF ports on the Slot 2, but this is valid for ALL IRF members, not only for Standby. This is a simple rule that will potentially save you a LOT of troubles when configuring IRF stack will all cables already plugged in.
