Is Airwave 8.2 supports RAID 1?
  • 1.  Is Airwave 8.2 supports RAID 1?
    Posted Jul 19, 2016 11:51 PM
    Hi all,
    Just a quick question. I've go thru the airwave 8.2 server sizing and found that it only support RAID 10 which is 1+0.
    Does it mean RAID1 is supported as well?
    Please advise.
    Thanks.
  • 2.  RE: Is Airwave 8.2 supports RAID 1?
    Posted Jul 20, 2016 12:03 AM
    RAID 1 is technically slower than RAID10. If you can build an array of disks that meet the IOPS requirement in RAID1, you would be fine, but the disks would likely need to be SSDs, or your AMP would need to be sufficiantly small such that a low IOPS count is required.
    How many devices and clients, and what types of devices will your AMP be monitoring?
  • 3.  RE: Is Airwave 8.2 supports RAID 1?
    Posted Jul 20, 2016 12:05 AM
    hi jhoward,
    less than 100 monitored devices ..aruba AP + controller.
    Clients i'm not sure.
    Would it be ok?
    thanks.
  • 4.  RE: Is Airwave 8.2 supports RAID 1?
    Posted Jul 20, 2016 12:10 AM
    Just meet the IOPS requirement for that amount of devices (100 devices should be around 500 clients, give or take), and you should be fine. Just note that RAID1 is usually at or slightly below the single disk IOPS value (if you have a validated controller, they will provide IOPS costs).
  • 5.  RE: Is Airwave 8.2 supports RAID 1?
    Posted Jul 20, 2016 12:12 AM
    Also, RAID10 is faster than RAID0 in most cases, which is why RAID10 is the recommendation and the one TAC will support.
  • 6.  RE: Is Airwave 8.2 supports RAID 1?
    Posted Jul 20, 2016 12:23 AM
    noted on the IOPS.
    Thus can I say raid 1 is supported as long as meet the IOPS value?
    Thanks.
  • 7.  RE: Is Airwave 8.2 supports RAID 1?
    Posted Jul 20, 2016 12:36 AM
    For that small of a device count you should be fine.
