Wired Intelligent Edge
Is ARUBA gre layer2 tunnel compatible with RFC 1701 GRE transparent ethernet bridging
  • 1.  Is ARUBA gre layer2 tunnel compatible with RFC 1701 GRE transparent ethernet bridging
    Posted Jun 19, 2016 05:05 PM
    Hello
    I am trying to establish an L2 encapsulation in a GRE tunnel between AMC and a third party device (VyOS router 1.1.7 with gre-bridge feature).
    On the capture, the only one difference i have seen is the 802.1Q tag inside the encapsulated frame from the controller, and the response without this tag.
    Do the controller accept such untagged frames ?
    Pierre
  • 2.  RE: Is ARUBA gre layer2 tunnel compatible with RFC 1701 GRE transparent ethernet bridging
    Posted Jun 22, 2016 03:56 PM
    Hi Finally I find the solution... I have used the "ip link gretap" directive on my Vyos router, and I can tag frames 802.1q into a gre tunnel... All works and I have to improve some tunnel parameters... Pierre
    #AirheadsMobile
  • 3.  RE: Is ARUBA gre layer2 tunnel compatible with RFC 1701 GRE transparent ethernet bridging
    Posted Jun 23, 2017 09:20 AM
    It works quite perfectly .... but some GRE packet are sent with a flag on GRE Header that contain a not null value (like DNS requests issued by Apple devices).
    The RFC says that value (Flags field of the GRE header) must be null otherwyse the recipient drop the packet ...
    I don't know how to modify this GRE packet tagging!!!
    Rgds
