Is FTRJ8519P1BNL-PT comaptible with M3 controller?
  • 1.  Is FTRJ8519P1BNL-PT comaptible with M3 controller?
    Posted May 05, 2015 11:33 AM
    Hi All,
    I would like to confirm if FTRJ8519P1BNL-PT is comaptible with M3 controller or not. I checked in Aruba Interoperability list and I do not see it listed.
    Below is the output about the SFP being used;
    # show interface gigabitethernet 0/0 transceiver
    Module is SFP
    Manufacturer : FINISAR CORP.
    Part Number : FTRJ8519P1BNL-PT, rev: A
    S/N : P9H17A4
    Date Code : 060501 Lot:
    Optional Signals : LOS Tx Disable
    Supported Modes : 1000Base-SX, LC Connector
    Thanks in advance.
    Karthikeyan Mookkandi
  • 2.  RE: Is FTRJ8519P1BNL-PT comaptible with M3 controller?
    Posted May 05, 2015 11:56 AM
    If it is not on the list or in the M3 installation guide, it is not supported.  It might work, though.
  • 3.  RE: Is FTRJ8519P1BNL-PT comaptible with M3 controller?
    Posted May 05, 2015 12:11 PM
    Thank you!
