is it possible to disable one frequency on the aruba 105 ap
  • 1.  is it possible to disable one frequency on the aruba 105 ap
    Posted May 06, 2015 12:01 PM
    we are installing wireless camera's throughout the campus and the vendor needs to have static frequencies in the 2.4 or 5ghz range. Is it possible to block channels on the aurba ap to accomodate this reqeust?
    Thank you for your reply.
  • 2.  RE: is it possible to disable one frequency on the aruba 105 ap
    Posted May 06, 2015 12:03 PM
    Are you looking to do static channel assignment or limit the channels which
    the AP will assign?
  • 3.  RE: is it possible to disable one frequency on the aruba 105 ap
    Posted May 06, 2015 12:06 PM
    I would like to limit the channels the ap assign, provide the vendor gives me a list of frequencies the camera's will be assigned.
    Thank you for the quick respond.
    Will Grimes
    [http://www.nationalchamps.net/Helmet_Project/Delaware_St.gif]Telecommunication Technician
    Ellucian
    1200 N. DuPont Hwy.
    Dover, DE 19001
    Offfice: (302) 857-7035
    Fax: (302) 857-7025
    "Have a fine university day"
  • 4.  RE: is it possible to disable one frequency on the aruba 105 ap
    Posted May 06, 2015 12:09 PM
    In the AP group, under AP, create a new Regulatory Domain profile with the
    channels you want to allow.
