Hi, folks.I'd like to disable the Web GUI for the controller and only use the CLIIs it possible to disable the Web GUI access ? ArubaOS (MODEL: RAP-109), Version 6.4.2.0-4.1.1.0 regards, -mitsu
No, this is not currently possible.
Hi Tim-san,
Thank you for replying.
OK
I'll try to insert a firewall rule which blocks traffic to the IP address of the controller using TCP 4343
Regards,-mitsu
Thanks for the info.
I tried the following config.
but it does not work.
inbound-firewall rule any any masterip 0.0.0.0 match tcp 4343 4343 deny
Thanks anyway.
I look for a different way.
I could be confirmed with this config.Thanks a lot.
