Is it possible to get use the 'magicvlan' ID3333 to provide guests with a option 252 DHCP PAC?
  • 1.  Is it possible to get use the 'magicvlan' ID3333 to provide guests with a option 252 DHCP PAC?
    Posted Feb 10, 2015 07:24 AM
    Hi
    I would like to use the default 'magicvlan' which is automatically set up when creating a 'guest' WLAN profile but I would like the internal DHCP to issue 'guests' on this SSID an option 252 proxy server address (10.10.xx.xx).  Is this possible using the CLI?
    If so could some one provide me with the commands?
  • 2.  RE: Is it possible to get use the 'magicvlan' ID3333 to provide guests with a option 252 DHCP PAC?
    Posted Feb 10, 2015 02:46 PM
    This is not possible with the built in "virtual controller assigned" DHCP method.  There may be a workaround where you can create a VLAN with a local DHCP scope and then src nat all the traffic out of the VC. However, you would then be responsible for trunking the created VLAN ID on the LAN.
    You're easier option is to use a VLAN on the LAN and a DHCP in the LAN as well to assign the option value...
  • 3.  RE: Is it possible to get use the 'magicvlan' ID3333 to provide guests with a option 252 DHCP PAC?
    Posted Feb 11, 2015 06:03 AM
    Many thanks for your reply. I was thinking the same thing. Regards David
