is it possible to have APs with different country codes linked to the same Master VC?
  • 1.  is it possible to have APs with different country codes linked to the same Master VC?
    Posted Mar 25, 2016 01:14 PM
    See Subject Header.
  • 2.  RE: is it possible to have APs with different country codes linked to the same Master VC?
    Posted Mar 25, 2016 01:16 PM
    Since the country code is set at the VC, that would be no.
  • 3.  RE: is it possible to have APs with different country codes linked to the same Master VC?
    Posted Mar 25, 2016 01:40 PM
    I two US APs in my Home lab and one Worldwide. The US versions is of cause
    fixed and one of those is the one I prefer to be VC.
    At what level does the discovery protocol for Joining run? I suspect L2. Is
    that correct.
    If I can not use all my APs in the samr VC I will end up with 2 VCs
    (correct ?)
    Even by using two different IP subnets will this will still cause problems
    if the are on the same VLAN? Actually default VLAN.
    I f was to simulate solution with 2 APs in the US and one in a remote
    network in EU linked to the same network, what do I need to do?
  • 4.  RE: is it possible to have APs with different country codes linked to the same Master VC?
    Posted Mar 25, 2016 02:15 PM
    It will not join the cluster of the existing VC nor it'll become a separate VC. You need to convert it to standalone mode and use it with a different country code on the same VLAN.
