Is it possible to limit client access to APs based on a time range?
  • 1.  Is it possible to limit client access to APs based on a time range?
    Posted Apr 02, 2015 01:45 PM
    I want to basically disable access to the SSIDs on my APs over the weekend, but don't see an "access hours" feature in Aruba Central.  Does this feature exist?
    Thanks.
  • 2.  RE: Is it possible to limit client access to APs based on a time range?
    Posted Apr 02, 2015 11:35 PM
    HI,
    It is not possible through Aruba Central but possible if you manage IAPs through Airwave.
    Please feel free for any further query on this
  • 3.  RE: Is it possible to limit client access to APs based on a time range?
    Posted Apr 03, 2015 08:41 AM
    Is Airwave an add-on or would i have to disconnect the APs i want to apply this to from Aruba Central and manage them separately?
  • 4.  RE: Is it possible to limit client access to APs based on a time range?
    Posted Apr 06, 2015 09:32 AM
    That feature will be built into the IAPs in a later release.
    Airwave is a separate monitoring/management platform. You would have to disconnect the APs from Central and move them to Airwave.
    Please speak with your Aruba account rep to see when this feature will come to Central
