Is it possible to modify a report definition in AMP 7.5.5?
  • 1.  Is it possible to modify a report definition in AMP 7.5.5?
    Posted Oct 18, 2013 12:08 PM
    I've created a custom report definition in AMP 7.5.5 and would like to know if it's possible to modify the "Most Utilized by Maximum Concurrent Clients" report under the "Device Summary" option.  I would like to have this report breakdown the "Max Concurrent Polled Clients" by SSID.  Does anyone know if this is possible?
    Thank you for your help,
    Eric Reyes
    Vital Network Services
  • 2.  RE: Is it possible to modify a report definition in AMP 7.5.5?
    Posted Oct 18, 2013 08:33 PM
    You can modify this report you created and select each SSID separately.  You would end up with multiple reports per SSID.  You can also setup a trigger for X concurrent clients over Y time on Z SSID.  That would make things a bit more proactive.
