Is it possible to use two gateways on the controller?
  • 1.  Is it possible to use two gateways on the controller?
    Posted Feb 21, 2012 07:43 AM
    Customer wants to make one VLAN users to go through a different gateway. is it possible?
  • 2.  RE: Is it possible to use two gateways on the controller?
    Posted Feb 21, 2012 09:23 AM
    Is the L3 gateway for the VLAN on the Aruba controller?  If so, then you will not be able to do this.  Best way to do this is to terminate the L3 gateway on the upstream device/router.  As far as I know Aruba does not yet support PBR or source base routing.
    -Mike
  • 3.  RE: Is it possible to use two gateways on the controller?
    Posted Feb 21, 2012 09:50 AM
    L3 gateway is aruba controller but if it is possible by any means we can change the configuration if we have to, how can it be done when we change the L3 gateway to the device/router? ( configuration side ).
    Thanks for ur  help
  • 4.  RE: Is it possible to use two gateways on the controller?
    Posted Feb 21, 2012 10:10 AM
    Let's assume VLAN100 is the VLAN you want to make the modifications to:
    - VLAN100
    - Network: 192.168.100.0/24
    - Gateway: 192.168.100.1/24 (Terminates on the Aruba controller)
    - Assuming you use an external DHCP server to hand out IPs for VLAN100
    You have 2 ways to make this changes:
    Option1:
    • Remove the L3 IP for VLAN100 (if it's not required for any other functionality)
    • Assign the L3 IP to your upstream router/gateway
    • Trunk VLAN100 to the Aruba controller so the router and Aruba controller are part of VLAN100
    • Update routing for VLAN100 (core/upstream)
    Options2:
    • Trunk VLAN100 to the controller so router/controller are part of VLAN100
    • Assign a different IP to the router for VLAN100
    • On DHCP server, change the gateway to the IP of the router in VLAN100
    With Option1 the controller is just L2 in VLAN100.  With Option2 the controller remain L3 but is not the default gateway for the VLAN100.  You may require Option2 if you're using Captive Portal.  Otherwise, go with Option1 unless there is a need to a VLAN100 IP on your controller.  No other changes are required on the controller.
    Hope that helps.
    -Mike
