I hope it's correct to write here, it's my first time.
I need to know if it's possible to enable/disable the ssid on the Aruba Instant, without to use the Airwave. And how to do it, if possible.
Thanks!
Best regards.
Yep. It's mentioned in the Instant User Guide document which is hosted on the support site.
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=21951
The feature is called "Time Range Profiles" page 227.
Cheers
James
Thank you for the information.
