Is meshing supported in IAP 275?
  • 1.  Is meshing supported in IAP 275?
    Posted Jul 14, 2015 06:39 AM
    HI;
  • 2.  RE: Is meshing supported in IAP 275?
    Posted Jul 14, 2015 06:45 AM
    It is supported if you have the 4.2.0 beta code, available from the Aruba support site.
