last person joined: 8 hours ago
Is MU-MIMO enabled by default in IAP-325.
  • 1.  Is MU-MIMO enabled by default in IAP-325.
    Posted May 12, 2016 01:03 PM
    Is MU-MIMO enabled by default in IAP-325. I dont see any MU benefit with 2 MU clients.
    Wondering if anyone can recommend any command line commands to verify the clients are being detected as MU clients and the data being transmitted is MU data ond not plain old SU.
  • 2.  RE: Is MU-MIMO enabled by default in IAP-325.
    Posted May 12, 2016 01:06 PM
    Yes it is.
    show ap association | include M
    That command will filter out clients with the M flag which is MU beam formee
  • 3.  RE: Is MU-MIMO enabled by default in IAP-325.
    Posted May 12, 2016 01:38 PM
    Thanks, this helps. Do you know if there are counters that will show the traffic being transmitted from the AP is using MU data frames ?
  • 4.  RE: Is MU-MIMO enabled by default in IAP-325.
    Posted May 12, 2016 01:57 PM
    show ap debug radio-stats ap-name <name of ap> radio 0 advanced | include MU
    show ap debug radio-stats ap-name <name of ap> radio 1 advanced | include MU
  • 5.  RE: Is MU-MIMO enabled by default in IAP-325.
    Posted Jan 10, 2019 07:11 AM
    Just a question, is it possible to disable MIMO on AP 300 type ?
    Best regards
