Wired Intelligent Edge
Is NQA + tracks (Feature) available on HPE OfficeConnect 1950 (Comware based Switch)
  • 1.  Is NQA + tracks (Feature) available on HPE OfficeConnect 1950 (Comware based Switch)
    Posted Mar 20, 2020 09:31 AM
    Everyone knows if 1950 switches has the following feature available in others comware switches:
    Network Quality Assuarance (NQA) and Tracks
    thanks
  • 2.  RE: Is NQA + tracks (Feature) available on HPE OfficeConnect 1950 (Comware based Switch)
    MVP GURU
    Posted Mar 20, 2020 12:02 PM
    Hi, I strongly doubt that the stripped down Comware 7 OS based  HPE OfficeConnect 1950 Switch series is capable to support NQA features (Note that NQA - Network Quality Analyzer - is a feature that allows you to measure network performance, verify the service levels for IP services and applications, and troubleshoot network problems).
    I saw NQA referenced only on mid/high-level full featured Comware 7 based HPE FlexFabric Switch Series (such as 59xx and 7900)...not on entry level (better, stripped down...from the features support standpoint) Switch Series such as the HPE OfficeConnect 1950 which can't exactly be compared to HPE FlexFabrics.
  • 3.  RE: Is NQA + tracks (Feature) available on HPE OfficeConnect 1950 (Comware based Switch)
    Posted Mar 23, 2020 11:04 AM
    indeed NQA was only available on the higher end switches.
    you can give it a try in the CLI but it would be surprised if it was implemented in the OC switches.
