Is possible to limit maximum users number and bandwidth in a WLC 7030?
  • 1.  Is possible to limit maximum users number and bandwidth in a WLC 7030?
    Posted Feb 18, 2015 10:43 PM
    I want to limit maximum number of users per SSID and bandwitdh per user. Is possible to do this, like is done with Virtual Controller?
  • 2.  RE: Is possible to limit maximum users number and bandwidth in a WLC 7030?
    Posted Feb 19, 2015 06:34 AM
    You would limit users per radio using the Max Associations parameter in the SSID profile http://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/VirtualAPs/SSID_Profiles.htm  By default this is 64.
    Clientmatch is enabled by default and will start load balancing devices at the "cm-lb-client-thresh"  (clientmatch load balancing) parameter in the ARM profile:    http://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/ARM/ARM_Profiles.htm%3FTocPath%3DAdaptive%20Radio%20Management%7C_____4
    Client Match        Enabled
    Client Match report interval (sec)                                           30
    Allows Client Match to automatically clear unsteerable clients after ageout  Enabled
    Client Match Unsteerable Client Ageout Interval                              2 Days 0 Hours
    Client Match Band Steer G Band Max Signal (-dBm)                             45
    Client Match Band Steer A Band Min Signal (-dBm)                             75
    Client Match Sticky Client Check Interval (sec)                              3
    Client Match Sticky client check SNR (dB)                                    18
    Client Match SNR threshold(dB)                                               5
    Client Match Sticky Min Signal                                               65
    Client Match Restriction timeout (sec)                                       10
    Client Match Load Balancing threshold (%)                                    20
    Client Match IOS Steer Backoff interval (sec)                                300
    Client Match VBR Stale Entry Age (sec)                                       120
    Client Match Max steer failures                                              2
    Client Match Load Balancing client threshold                                 30
    Client Match Load Balancing SNR threshold (dB)                               30
    Client Match Load Balancing signal delta bound (dB)                          5
    Client Match 11v BSS Transition Management                                   Enabled
     The bandwidth that a user is restricted is configured in the user role.
  • 3.  RE: Is possible to limit maximum users number and bandwidth in a WLC 7030?
    Posted Feb 20, 2015 08:21 PM
    You can limit users per radio per ssid in the ssid profile in the advanced mode (see the screen-shot)
    the bandwidht can be limited in the role  (see the screen-shot)
