Is there a CLI command to show air monitor details similar to what is in the GUI.
  • 1.  Is there a CLI command to show air monitor details similar to what is in the GUI.
    Posted Oct 18, 2017 12:28 PM
    When I do a "show ap database-summary" it shows that I have multiple are monitors.
    From the GUI I can easily click on "All Air Monitors to see them"
    Is there a CLI command to chow the same basic AM information (eg. Name, Ap Group, Status, IP,  etc...)  ?
  • 2.  RE: Is there a CLI command to show air monitor details similar to what is in the GUI.
    Posted Oct 18, 2017 12:46 PM
    you cna likely do a 'show ap database | include AM' (not it's case sensitive, but whatever is after the include would be a search string for any string in the line output.
  • 3.  RE: Is there a CLI command to show air monitor details similar to what is in the GUI.
    Posted Feb 12, 2018 11:42 AM
    Hi.
    Yeah I tried that and it did not show them.
    I have 32 AM's on a local controller and I tried to show them from both the master and the local and I can't find a command that does it from the CLI.
    The easiest way I can find it to go into the gui but if the gui can differenciate them I assume there has to be a way in the CLI to do the same.
    Dave
  • 4.  RE: Is there a CLI command to show air monitor details similar to what is in the GUI.
    Posted Feb 12, 2018 11:53 AM
    "show ap active | include AM"
  • 5.  RE: Is there a CLI command to show air monitor details similar to what is in the GUI.
    Posted Feb 12, 2018 11:56 AM
    That worked.
    Thanks Joseph.
