My 0:1 partition got corrupted from a failed upgrade and I can't change the setting for the default partition. I can boot into the 0:0 partition using cpboot, is there a command to hard set the default partition so I can use the WebUI again? Thanks
"boot flash 0:1" should do it.
Check out http://support.arubanetworks.com/ArubaOSKB/tabid/111/Default.aspx
oops.. "boot flash 0:0"
using bootf 0:0 loads that partition, I was able to get to the web interface after that, but not log in. One step closer. Thanks
