Is there a dummies guide for setting up a guest network?
  • 1.  Is there a dummies guide for setting up a guest network?
    Posted Jan 12, 2015 05:48 PM
    Setting up a production network for our new IAP-215 was pretty painless but I can't figure out how to set up a network for our guests.
    I'm using virtual controller assigned IP which is fine but when I connect my test client, our internal DNS server is listed. If I block all access to our 10.0.0.0 network then the guest client can't resolve addresses.
    Help. I'm a dummy.
  • 2.  RE: Is there a dummies guide for setting up a guest network?
    Posted Jan 12, 2015 05:50 PM
    Are you allowing internal dns before blocking all the internal space?
    Tim
  • 3.  RE: Is there a dummies guide for setting up a guest network?
    Posted Jan 12, 2015 05:59 PM
    Well that was easy. Thanks. I guess I was over thinking it and under thinking it at the same time if that's possible. Told you I was a dummy.
  • 4.  RE: Is there a dummies guide for setting up a guest network?
    Posted Jan 12, 2015 05:51 PM
    permit dns to anywhere, then block access to 10.0.0.0
