Is there a limit to the number of static routes on a controller?
  • 1.  Is there a limit to the number of static routes on a controller?
    Posted Apr 12, 2013 10:28 AM
    We have been using a 2400 to terminate a large number of GRE tunnels that we use to filter guest traffic to the Internet, but i just got an error on the max number of tunnels is between 128 and 133, which is the 1st time i have seen it...
    I am sure that I have over time added well over 128 routes since I have over 200 tunnels.
    Does anyone know the maximum number of static routes?  Currently we are running ver 5.0.4.10.
  • 2.  RE: Is there a limit to the number of static routes on a controller?
    Posted Apr 12, 2013 10:32 AM
    I don't think there is a limit from a configuration stand point that the controller will not allow you to but not sure if there's a best practice limitation
  • 3.  RE: Is there a limit to the number of static routes on a controller?
    Posted Apr 12, 2013 11:25 AM
    I would agree i couldn't find anything documented anywhere either but here is the error that i  received that toatlly threw me...
    (US-HAL-NP2-GRE1) (config) #ip route 34.184.137.0 255.255.255.0 10.10.10.145
    Exceeds maximum allowed static routesi Maximum allowed range is 128 - 133
  • 4.  RE: Is there a limit to the number of static routes on a controller?
    Posted Apr 13, 2013 10:20 AM
    128 IS the max for the 2400 series controller.  Later controllers do have a higher static route limit...
  • 5.  RE: Is there a limit to the number of static routes on a controller?
    Posted Apr 13, 2013 10:37 AM
    What about the 3600?
  • 6.  RE: Is there a limit to the number of static routes on a controller?
    Posted Apr 13, 2013 10:45 AM
    Please see the datasheet page here:  http://www.arubanetworks.com/?product=aruba-3000-controller-series
    Number of IPv4 unicast routes 2,048 2,048 2,048
  • 7.  RE: Is there a limit to the number of static routes on a controller?
    Posted Apr 16, 2013 03:30 PM
    Looks like I am going to have to open a TAC case on this, since after replacing the 2400 with the 3600 i got the same results....
    US-HAL-NP2-GRE1) (config) #ip route 34.188.135.0 255.255.255.0 10.10.10.121
  • 8.  RE: Is there a limit to the number of static routes on a controller?
    Posted Apr 16, 2013 03:32 PM
    What version of ArubaOs code?
  • 9.  RE: Is there a limit to the number of static routes on a controller?
    Posted Apr 16, 2013 04:36 PM
    5.0.3.3
  • 10.  RE: Is there a limit to the number of static routes on a controller?
    Posted Apr 16, 2013 04:37 PM
    That is a limitation of 5.0.3.3  if you upgrade 6.x that would lift the limitation.
  • 11.  RE: Is there a limit to the number of static routes on a controller?
    Posted Apr 16, 2013 05:01 PM
    Oh you are killin me!!!  :smileywink:  Will do....thanks!!!
  • 12.  RE: Is there a limit to the number of static routes on a controller?
    Posted Apr 16, 2013 10:35 PM
    So i upgraded and still have the limitation....
    (US-HAL-NP2-GRE1) (config) #ip route 34.188.135.0 255.255.255.0 10.10.10.121
    (US-HAL-NP2-GRE1) #show image ver
    Partition               : 0:0 (/dev/hda1) **Default boot**
    Software Version        : ArubaOS 6.1.3.7 (Digitally Signed - Production Build)
    Build number            : 37112
    Label                   : 37112
    Built on                : Fri Feb 8 18:31:05 PST 2013
    Partition               : 0:1 (/dev/hda2)
    Software Version        : ArubaOS 5.0.3.3 (Digitally Signed - Production Build)
    Build number            : 28008
    Label                   : 28008
    Built on                : Thu Apr 21 11:52:06 PDT 2011
    (US-HAL-NP2-GRE1) #
  • 13.  RE: Is there a limit to the number of static routes on a controller?
    Posted Apr 17, 2013 12:44 AM
    Hmm... support case.
  • 14.  RE: Is there a limit to the number of static routes on a controller?
    Posted May 02, 2013 10:25 PM
    Just got the word back from engineering that it is not a bug but expected.
    "We have a limit of 128 static routes that can be configured on the controller and we have hit that limit."
    So not that is in the documentation that i could find but on controllers it needs to be noted somewhere that they can only support 128 static routes....
  • 15.  RE: Is there a limit to the number of static routes on a controller?
    Posted Apr 13, 2013 10:56 AM
    Thanks cjoseph , good to know .. I was looking in the wrong places
