is there a limited devices for a Group
  • 1.  is there a limited devices for a Group
    Posted Sep 07, 2016 10:14 AM
    I have a Airwave with more than 1600 devices, and I have a group with more than 1400 devices. It's a problem??
    I'm asking this because there are a lot of bad behavior from de AirWave like:
    - after updating a template it takes more than 2  to 4 hours to show "Good" on status colum
    - after adding a new device it takes more than 2 to 4 Hours to show "Good" on status colum
    - there also devices that are in permanently verifying status
    strange behaviors that I didn’t have at the beginning
    We went to the version 8.0.11.2 and the AppRF stop Working.
    There are just to many issues and the Airwave is not doing is thing, like being a monitor tool for the IAP's
  • 2.  RE: is there a limited devices for a Group
    Posted Sep 07, 2016 10:24 AM
    You could have other things going on, so you should open a case with TAC.  Your problems might not be caused by having 1600 devices, but they could be a symptom of something else.  They can take a look at everything including network bandwidth, configuration and possible horsepower of your box to determine what could be the cause of your issues.
