Is there a "reload in" command to reload the controller in 10 hours or something similar
This thread has been viewed 16 times
  • 1.  Is there a "reload in" command to reload the controller in 10 hours or something similar
    Posted Nov 04, 2013 09:15 AM
    reload in?
    reload at?
  • 2.  RE: Is there a "reload in" command to reload the controller in 10 hours or something similar
    Posted Nov 04, 2013 10:01 AM
    No.  However, you can schedule with Airwave
  • 3.  RE: Is there a "reload in" command to reload the controller in 10 hours or something similar
    Posted Nov 04, 2013 10:03 AM
    That's unfortunate.  Thanks for the info!
  • 4.  RE: Is there a "reload in" command to reload the controller in 10 hours or something similar
    Posted Nov 04, 2013 10:32 AM
    You could use Cattools and it allows you to schedule a certain task to the controller like automatic backups and for your case you could use it to do an automatic reload of the controller
    http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-Automating-Aruba-Controller-Tasks-with-Kiwi-CatTools/m-p/1365/highlight/true#M92
  • 5.  RE: Is there a "reload in" command to reload the controller in 10 hours or something similar
    Posted Nov 12, 2015 09:30 AM
    Hi
    Aruba should implement both the "reload at" and "reload in" command.
    The scheduled "reload at" would be nice of you wan't to reboot at night. I understand this could be done in Airwave, but not all our customers have AirWave.
    The "reload in" would be useful for when devices are at remote locations and you need to do changes that might break your connection or whatever.
    Just instruct the controller to "reload in 5 minutes", if all goes well, you just abort. If you loose connection, then the system will come back up after the reboot as the config is not saved.
    Roar
  • 6.  RE: Is there a "reload in" command to reload the controller in 10 hours or something similar
    Posted Nov 12, 2015 12:06 PM
    Agreed. A "Reload in X" would be really useful at times.
  • 7.  RE: Is there a "reload in" command to reload the controller in 10 hours or something similar
    Posted Dec 20, 2015 07:56 AM
    sounds like something for idea portal: http://community.arubanetworks.com/t5/Ideas/ct-p/ideas
    or a formal feature request. ill vote on it for sure.
  • 8.  RE: Is there a "reload in" command to reload the controller in 10 hours or something similar
    Posted Mar 17, 2022 01:55 PM
    No. However, you can schedule in on a linux box with "at" or "cron" in conjunctions with a controller rest api url :
    sessionid=`curl -s --insecure -c "$0-$$-cookie" -d "username=$adminuser&password=$password" https://${controller}:4343/v1/api/login | jq -r '._global_result.UIDARUBA' `
    curl -s --insecure -b "$0-$$-cookie" -X POST -i "https://${controller}/v1/configuration/object/reload?UIDARUBA=$sessionid"
    Daniele Albrizio
