Is there a way to create a few permanent guest members as well as use the Guest Registration Process
  • 1.  Is there a way to create a few permanent guest members as well as use the Guest Registration Process
    Posted Feb 06, 2014 11:38 AM
    Is there a way to create a few permanent guest members as well as use the Guest Registration Process?  I have a couple users that are here fairly often, but I want to keep them on our guest SSID.  I do not want them to have to fill out the guest registration everytime they are here.  I try to go in and manually set their accounts to never expire, but it never works.  Any help is greatly appreciated.
  • 2.  RE: Is there a way to create a few permanent guest members as well as use the Guest Registration Process
    Posted Feb 06, 2014 12:30 PM
    Yes
  • 3.  RE: Is there a way to create a few permanent guest members as well as use the Guest Registration Process
    Posted Feb 06, 2014 12:42 PM
    Perfect, how would I do such a thing?
    Sent from my Verizon Wireless 4G LTE Smartphone
  • 4.  RE: Is there a way to create a few permanent guest members as well as use the Guest Registration Process
    Posted Feb 06, 2014 12:44 PM
    I attached a screen shot
  • 5.  RE: Is there a way to create a few permanent guest members as well as use the Guest Registration Process
    Posted Feb 06, 2014 01:12 PM
    I appreciate your response.  I have tried this solution before but these users still get the guest registration screen when they leave and re-enter the building.
  • 6.  RE: Is there a way to create a few permanent guest members as well as use the Guest Registration Process
    Posted Feb 06, 2014 01:17 PM
    Sounds like you don't have Mac caching turned on.
  • 7.  RE: Is there a way to create a few permanent guest members as well as use the Guest Registration Process
    Posted Feb 06, 2014 01:58 PM
    On CP or the controller?
  • 8.  RE: Is there a way to create a few permanent guest members as well as use the Guest Registration Process
    Posted Feb 06, 2014 09:45 PM
    On controller. You should enable MAC Authentication and authenticate via CPPM.
  • 9.  RE: Is there a way to create a few permanent guest members as well as use the Guest Registration Process
    Posted Feb 07, 2014 03:10 AM
    In clearpass when you set up the Guest services you can use the service templates and use
    It will create two services. One for the first time they hit the captive portal and One for when they get disconnected and reconnect.
    Here is what the MAC auth service looks like..
