Is there a way to disable purge feature on the Aruba controller ?
  • 1.  Is there a way to disable purge feature on the Aruba controller ?
    Posted Jan 16, 2015 02:17 AM
    Is there a way to disable Purge feature that is available while adding Rap in the whitelist db on the controller?
    If an user accidently click the purge, we loose the rap  database and I am looking for a way to prevent an user for using that command.
    Raja
  • 2.  RE: Is there a way to disable purge feature on the Aruba controller ?
    Posted Jan 16, 2015 08:56 PM
    There is no way to do that, unfortunately.
