is there a way to get a report on airwave that shows AP ethe interface status and errors
  • 1.  is there a way to get a report on airwave that shows AP ethe interface status and errors
    Posted Dec 06, 2016 10:31 AM
     I would like to get a report on airwave that shows the status and stats for the ethernet interfaces on the AP (from the AP's standpoint).   We have had some switch ports that are hard coded (100/full ) and since the AP's are auto they will end up half duplex and cause issues.  anyone know of a report on airwave that I can run to get this info?  or a quick look on the controller that will show this on all AP's?
  • 2.  RE: is there a way to get a report on airwave that shows AP ethe interface status and errors
    Posted Dec 06, 2016 10:58 AM
    The following report will show you what you're after I believe.
    Shows this:
    Cheers
    James
  • 3.  RE: is there a way to get a report on airwave that shows AP ethe interface status and errors
    Posted Dec 06, 2016 11:12 AM
    that gets me what I need Thank You.
