Our district just got Aruba s2500's in and we were wondering, if there was a way we can easily use the configuration from our Cisco 3750 switches for the Aruba switches. We're planning on using a trunk port to go from the Cisco Switch to the Aruba switch as well.
Thanks!
The Aruba MAS configuration is profile based so you cannot import the configuration directly.
Some of the commands are similar though, for example:
interface vlan 10
ip address 10.1.1.1 255.255.255.0
no shut
show ip interface brief
show vlan
