Is there a way to reset the controller 620 before the boot %3F
  • 1.  Is there a way to reset the controller 620 before the boot %3F
    Posted Jan 15, 2016 07:52 AM
    Hello to all,
    I've got a little problem. I have a controller 620 that I used to perform some tests, however, My coleague forget the password and I would like to know if is there a way to erase the controller to default before pass the boot ?
    Thank you so much for all of you.
  • 2.  RE: Is there a way to reset the controller 620 before the boot %3F
    MVP
    Posted Jan 15, 2016 07:50 PM
    Please login using console with a serial cable (e.g. you must be infront of the controller):
    Login: password
    Password: forgetme!
    Then go into enable mode with password “enable”
    Config terminal
    mgmt-user admin root
    <hit enter and it will ask you for a new root password>
    logout and login back in
    Then write memory
  • 3.  RE: Is there a way to reset the controller 620 before the boot %3F
    MVP
    Posted Jan 15, 2016 07:53 PM
    Login: password
    Password: forgetme!
    config terminal
    Followed by write memory
  • 4.  RE: Is there a way to reset the controller 620 before the boot %3F
    Posted Jan 17, 2016 11:03 AM
    Second part, if you are in following the password reset procedure, the command to factory-default the controller is: write erase all
    Make sure that before you do that, the licenses are recorded so you can put them back after the factory reset. Use the WebUI for that or on the CLI the command: show licenses.
