is there an easy way to tell if a 3200 has the extended memory?
  • 1.  is there an easy way to tell if a 3200 has the extended memory?
    Posted Jun 15, 2014 07:34 PM
    either 3200 xm or if it has the required memory to be an XM from the CLI or GUI?
    #3200
  • 2.  RE: is there an easy way to tell if a 3200 has the extended memory?
    Posted Jun 15, 2014 07:38 PM
    On the cli, type "show memory".  The XM should have 2gig of memory.  The 3200 should have 1 gig or less.   Edit.  Please see below:
  • 3.  RE: is there an easy way to tell if a 3200 has the extended memory?
    Posted Jun 15, 2014 07:39 PM
    perfect thank you!
  • 4.  RE: is there an easy way to tell if a 3200 has the extended memory?
    Posted Jun 16, 2014 03:59 AM
    Edit:
    1. Show memory command output:
    (Aruba3200) #show memory
    Memory (Kb): total: 354048, used: 261916, free: 92132
    Below is the CLI output from a 3200 after the memory upgrade not 3200XM hardware.
    (Aruba3200XM) #show memory
    Memory (Kb): total: 691968, used: 456660, free: 235308
    Above you can note two things: Total and Free memory:
    Total: 354048Kb for 3200 without extended memory
    Total: 691968Kb for 3200XM with extended memory
