Is there any single command to show configuration for all nodes from Mobility Master?
This thread has been viewed 19 times
  • 1.  Is there any single command to show configuration for all nodes from Mobility Master?
    Posted Nov 20, 2020 09:39 AM
    When connected to Mobility Master, is there any single command to show configuration for /md and all folder/nodes under it? I want to take backup of configuration using one command only instead of moving between nodes/folder to collect configuration at every level.
    Thank you,
    Ahmad Enaya
  • 2.  RE: Is there any single command to show configuration for all nodes from Mobility Master?
    MVP GURU
    Posted Nov 20, 2020 10:05 AM
    No single command to show config at each level. Are you not able to backup the MM to a TFTP/FTP or other external server? The flashbackup of the MM will include the config at each level below. See the screenshot below. There will be a config file for each level below including the settings that differ from the levels above.
    Dustin Burns
  • 3.  RE: Is there any single command to show configuration for all nodes from Mobility Master?
    Posted Nov 20, 2020 01:00 PM
    To be clear, the backup configuration dialog on the MM will backup the entire config in a configbackup.tar.gz file.
