Is there way to enable - disable an ssid by time of day using virtual controller and AP-105
  • 1.  Is there way to enable - disable an ssid by time of day using virtual controller and AP-105
    Posted Feb 11, 2015 06:28 PM
    Excuse me i this is not the right place to post this question - it is my first time.  I'm wondering if it is possible to enable and disable my guest wireless ssid automatically depending on time of day.  This is my current version.
    ArubaOS (MODEL: 105), Version 6.3.1.4-4.0.0.6
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2014, Aruba Networks, Inc.
    Compiled on 2014-06-05 at 09:52:43 PDT (build 44126) by p4build
  • 2.  RE: Is there way to enable - disable an ssid by time of day using virtual controller and AP-105
    Posted Feb 15, 2015 10:17 AM
    this is totally the right place.
    unfortunately this isn't possible with the Instant software. if you are good enough with scripting you might be able to build something on another system, but that is it.
  • 3.  RE: Is there way to enable - disable an ssid by time of day using virtual controller and AP-105
    Posted Feb 15, 2015 11:16 AM
    If you have AirWave, you can schedule it there.
    Tim
  • 4.  RE: Is there way to enable - disable an ssid by time of day using virtual controller and AP-105
    Posted Feb 16, 2015 08:33 AM
    Thanks for your reply - I am checking into airwave to see what that is all about.
