I done my best "guesswork" for this configuration, but the iSCSI access seems to be slower than my previous Dell N4024 stack
Output from one iSCSI dedicated port:
[HPE5900-SR1]dis interface Ten-GigabitEthernet 4/0/33
Ten-GigabitEthernet4/0/33
Current state: UP
Line protocol state: UP
IP packet frame type: Ethernet II, hardware address: 2c23-3abd-4648
Description: Ten-GigabitEthernet4/0/33 Interface
Bandwidth: 10000000 kbps
Loopback is not set
Media type is twisted pair
port hardware type is 10G_BASE_T
10Gbps-speed mode, full-duplex mode
Link speed type is autonegotiation, link duplex type is autonegotiation
Flow-control receive enabled
Maximum frame length: 10000
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 77
MDI type: Automdix
Port link-type: Access
Tagged VLANs: None
Untagged VLANs: 77
Port priority: 0
Last clearing of counters: Never
Peak input rate: 67929207 bytes/sec, at 2016-10-24 19:05:23
Peak output rate: 20791021 bytes/sec, at 2016-10-21 20:11:38
Last 300 second input: 530 packets/sec 3342134 bytes/sec 0%
Last 300 second output: 418 packets/sec 681748 bytes/sec 0%
Input (total): 508503915 packets, 3395785841360 bytes
508467805 unicasts, 0 broadcasts, 0 multicasts, 36110 pauses
Input (normal): 508467805 packets, - bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
0 CRC, 0 frame, - overruns, 0 aborts
- ignored, - parity errors
Output (total): 363930564 packets, 619066646134 bytes
362466851 unicasts, 674021 broadcasts, 789692 multicasts, 0 pauses
Output (normal): 363930564 packets, - bytes
Output: 0 output errors, - underruns, - buffer failures
0 aborts, 0 deferred, 0 collisions, 0 late collisions
0 lost carrier, - no carrier
Anybody has any constructive input?
Seb
