Hi All,
I'm a very new user to Aruba equipment. I've got the basics down and I have an Aruba 3200 with 6 AP105's that are working just fine. The current environment is pretty standard and is in use by our internal employees and protected via WPA2 aes/tkip.
I'd like to add a guest network that is connected to the OPT port of my m0n0wall router, but I'm having some trouble getting it set up correctly. My reason for using the OPT port is because I'd like to have public traffic routed through a different static IP that my production network.
My router is configured at 192.168.x.1, DNS forwarding is enabled and pushing out to public addresses. If I plug my laptop directly into this interface and set a static address, I can browse just fine. I'm using the built in throttle options for the m0n0wall and they are tested and working fine on this interface.
DHCP was enabled for this network via the m0n0wall, but I have since disabled it to see if I could have the Aruba controller handle it.
I set up a VLAN per documentation, am pointing to the router as the default router address, have DHCP enabled on the subnet within the Aruba controller, and have the new SSID pointed to the correct VLAN. I have the VLAN pointing to Port 1, which is where my interface from my OPT network on my m0n0wall is connected to.
I can't even get a DHCP address issued when I successfully connect to the new SSID, that's even with the SSID tied to that VLAN.
Any thoughts or input?
