Cloud Managed Networks
Issue Server Reject with cloudauth in aruba central with AD Azure
This thread has been viewed 37 times
  • 1.  Issue Server Reject with cloudauth in aruba central with AD Azure
    Posted May 06, 2022 06:32 PM
    Dear Community.
    I have the following case with the central Aruba cloudauth integrated with the Active Directory in Azure.
    In the authentication and access process, the rad-recj, eap-failure, and server failure messages are observed.
    Auth Trace Buffer
    May 5 10:55:34 eap-failure <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 8 4 server rejected
    May 5 10:55:35 station-up * e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 - - wpa2 aes
    May 5 10:55:35 eap-id-req <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 10 5
    May 5 10:55:35 eap-start -> e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 - -
    May 5 10:55:40 eap-id-req <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 10 5
    May 5 10:55:41 eap-id-resp -> e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 10 21 jampier.valdivia
    May 5 10:55:41 rad-req -> e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 1 345 a9e560f3-537e-4206-8bda-0baa7ba5
    May 5 10:55:41 rad-resp <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71/AS1_#guest#_ 1 -
    May 5 10:55:41 eap-req <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 11 6
    May 5 10:55:41 eap-nak -> e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 11 7
    May 5 10:55:41 rad-req -> e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71/AS1_#guest#_ 1 349 a9e560f3-537e-4206-8bda-0baa7ba5
    May 5 10:55:41 rad-reject <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71/AS1_#guest#_ 1 -
    May 5 10:55:41 eap-failure <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 11 4 server rejected
    May 5 10:56:12 eap-id-req <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 12 5
    May 5 10:56:17 eap-id-req <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 13 5
    May 5 10:56:22 eap-id-req <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 13 5
    May 5 10:56:27 eap-id-req <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 13 5
    May 5 10:56:32 eap-id-req <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 14 5
    May 5 10:56:37 eap-id-req <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 14 5
    May 5 10:56:42 eap-id-req <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 14 5
    May 5 10:56:47 eap-id-req <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 15 5
    May 5 10:56:52 eap-id-req <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 15 5
    May 5 10:56:57 eap-id-req <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 15 5
    May 5 10:57:03 eap-id-req <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 16 5
    May 5 10:57:08 eap-id-req <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 16 5
    May 5 10:57:13 eap-id-req <- e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 16 5
    May 5 10:57:18 dot1x-timeout * e4:a4:71:e4:1b:a0 6c:c4:9f:25:6d:71 17 512 station timeout
    6c:c4:9f:ca:56:d6#
    In the configuration process, the guides and recommendations were followed step by step, not encountering problems, and observing the correct one.
    operation in central Aruba with AD connection.
    The problem occurs with users who try to access the wireless network, through the cloudauth method.
    Please help me this case.
    Felipe H.V
    Felipe Herrera
  • 2.  RE: Issue Server Reject with cloudauth in aruba central with AD Azure
    Posted May 10, 2022 07:25 AM
    What is most likely is that your user is not in the right Azure AD group that you selected. You could check the authentication logs (Global View, Security, Authentication and Policy, List view) and check the authentication log there for a reason that the authentication was rejected.
  • 3.  RE: Issue Server Reject with cloudauth in aruba central with AD Azure
    Posted May 24, 2022 01:55 AM
    Hi Felipe,
    I’ve been attempting to configure this as well, mostly by trial and error. I can find very little in the way of documentation or guides. Any links are greatly appreciated?
    Lyle
    Lyle Lee
  • 4.  RE: Issue Server Reject with cloudauth in aruba central with AD Azure
    Posted May 31, 2022 08:07 AM
    For the connection of the final client with the Azure cloud, it is necessary to use the Aruba Onboard Application for the connection with a certificate.
    Below is the link:
    https://www.arubanetworks.com/techdocs/central/latest/content/nms/policy/prov-mobile-app.htm
    Fernando Ramos Huayhua
