Issue setting up external splash page for quest network
  • 1.  Issue setting up external splash page for quest network
    Posted Jan 07, 2015 02:07 PM
    I am trying to setup an external splash page that is hosted on one of my internal servers. And we are getting the message "Enter a valid url" when trying to put in the pages URL.
    URL is this: http://172.23.35.50:8087/GuestWirelessSplashPage
    Any ideas on what I am doing wrong?  Also we are not sure what the process will be for this page in terms of accepting terms before getting network access. Do we need to create an accept button on the page that links to something? I have attached screen shot so that you can see what I am looking at.
  • 2.  RE: Issue setting up external splash page for quest network
    Posted Jan 07, 2015 02:19 PM
    You do it , this way :
    add the IP and then add this part /GuestWirelessSplashPage.php in the URL
  • 3.  RE: Issue setting up external splash page for quest network
    Posted Jan 07, 2015 02:23 PM
    Does it have to be PHP or can it be plain HTML?  Also how does the accept process work with an external page?
  • 4.  RE: Issue setting up external splash page for quest network
    Posted Jan 07, 2015 02:27 PM
    Yes you can , just make sure you can reach it .
    Also you can add 443 if your host server supports it.
  • 5.  RE: Issue setting up external splash page for quest network
    Posted Jan 07, 2015 02:33 PM
    How do users accept the terms I have on the page and get access to the network?   I can get to the page when joining the guest network but therre is no way to proceed throught it.
  • 6.  RE: Issue setting up external splash page for quest network
  • 7.  RE: Issue setting up external splash page for quest network
    Posted Jan 07, 2015 03:49 PM
    I appreciate the link but this looks like its a work around and not the best way to do it. The solution suggested is over a year old now and I would think that there has to be a proper way to do this.
  • 8.  RE: Issue setting up external splash page for quest network
    Posted Jan 07, 2015 04:25 PM
    Your best options :
    - use the IAP internal page (limited in terms of what you can do)
    - use ClearPass Guest which more flexibility and control over what you can do with captive portal.
  • 9.  RE: Issue setting up external splash page for quest network
    Posted Jan 07, 2015 04:32 PM
    I am going to reach out to my sales rep and discuss thanks for the help.
