Issue while configuring Vlan DHCP Pool
  • 1.  Issue while configuring Vlan DHCP Pool
    Posted Jan 09, 2020 07:29 PM
    Hi Guys
    Hope everybody having good day
    i have an issue when i try to add dhcp vlan pool
    i wan t two add two dhcp pool for two van at my controller when i add one of them i got the below error
    Failed to add pool X which has 4094 addresses. Maximum addresses configurable is 4096 in the config path.
    Currently configured are 253 addresses. You may want to exclude unused address ranges.
    Thank you in advance for the answers
  • 2.  RE: Issue while configuring Vlan DHCP Pool
    Posted Jan 09, 2020 09:56 PM
    Controller DHCP servers have a limit to the size of their leases:
    https://community.arubanetworks.com/t5/Controller-Based-WLANs/8-x-Increase-DHCP-Lease-Limit/ta-p/393348
  • 3.  RE: Issue while configuring Vlan DHCP Pool
    Posted Jan 10, 2020 07:47 AM
    Thanks for replay
    but this only support 7005/7008/7010 series , but my controller is 7205 which is not on the list
    so when in try run ip dhcp increase-lease-limit  it say this command is not supporting on this platform
    thanks
  • 4.  RE: Issue while configuring Vlan DHCP Pool
    Posted Jan 10, 2020 07:58 AM
    Do you have a screenshot of what you were trying to do when you got the error and what version of ArubaOS you are running?
  • 5.  RE: Issue while configuring Vlan DHCP Pool
    Posted Jan 10, 2020 08:18 AM
    I am version 8.6.0.1
    once i run the folloing command
    ip dhcp pool vlan_90
    default-router 192.168.144.1
    domain-name aruba.local
    network 192.168.144.0 255.255.240.0
     i got the error below
    Failed to add pool vlan_90 which has 4094 addresses. Maximum addresses configurable is 4096 in the config path.
    Currently configured are 506 addresses. You may want to exclude unused address ranges.
    as well i can add dhcp pool with subnet 255.255.255.0 with no issue
    thanks
  • 6.  RE: Issue while configuring Vlan DHCP Pool
    Posted Jan 10, 2020 08:53 AM
    It sounds like your limit is 4096 addresses on that platform.  I would use an external dhcp server if you want to provide more addresses.
  • 7.  RE: Issue while configuring Vlan DHCP Pool
    Posted Jan 10, 2020 03:30 PM
