issue with AP 215
  • 1.  issue with AP 215
    Posted Nov 17, 2016 05:54 AM
    Hi Guys,
    There is issue with AP. AP is working fine but the problem is, In my desk I tried to connect the AP in my Laptop as well as Phone is not connecting to the nearby AP it’s directly goes to the far located AP. In-between from my desk to far located AP(connected AP) has 2 APs even those APs has not connected to my laptop so it’s result signal problem.
    In my nearby desk peoples has also same problem.
    I tried to use the Dual Band Adapter in my laptop which results the same issue. I have attached all documents with cited for problems. Please post all suggestions ASAP.
  • 2.  RE: issue with AP 215
    Posted Nov 17, 2016 07:01 AM
    Your transmit power is too high.  Under RF > ARM change the max transmiit power of the 2.4ghz to 15, instead of max.
  • 3.  RE: issue with AP 215
    Posted Nov 17, 2016 07:33 AM
    hi colin,
    after i did this changes now my AP is connecting to nearby or not?
  • 4.  RE: issue with AP 215
    Posted Nov 17, 2016 07:41 AM
    Hi Colin,
    Max transit power is 9 is not max, which one you kept talkin about. Am novice help me. i attached the image plz see or tell me the path of changes.
