We have a client that requires JAVA 6, it cannot use anything newer than that. If you try to client to it it says no connection in a dialog box from JAVA but the network icon in the sys tray of Windows never loses connection. We tried using it via an ethernet cable and it works fine. I have checked the datapath on the controller to see if it was getting blocked. It is not getting blocked. Any ideas would be helpful? Thank you.
