Issue with onboarding Android device
  • 1.  Issue with onboarding Android device
    Posted Nov 12, 2013 09:19 PM
    I am getting the following error after I enter the username and password in ClearPass QuickConnect when trying to onboard an Android device. I have no issues onboarding IOS devices.
    There was an error in configuring your device. Cannot download Device credentials from Onboard server: Value <!DOCTYPE of type java.lang.String cannot be converted to JSONObject.
    And I don't see any error messages in Access Tracker.
    Any ideas?
  • 2.  RE: Issue with onboarding Android device
    Posted Nov 12, 2013 09:22 PM
    Are there any errors in the application log on the guest side? (I doubt there are but just wanted to make sure)
    Home > Administration > Support > Application Log
  • 3.  RE: Issue with onboarding Android device
    Posted Nov 12, 2013 09:27 PM
    Troy,
    I don't see any errors under Application Log. They are all informational. I am trying to onboard both Samsung and Nexus tablets. Same result.
  • 4.  RE: Issue with onboarding Android device
    Posted Nov 12, 2013 09:44 PM
    Also what is the make/model/firmware of the device?
  • 5.  RE: Issue with onboarding Android device
    Posted Nov 12, 2013 09:47 PM
    Nexus 7, Android version 4.3, Model ME370T
    Model Number: Samsung GT-N8013, Android version 4.1.2
  • 6.  RE: Issue with onboarding Android device
    Posted Nov 12, 2013 09:54 PM
    Are you redirecting by IP or FQDN? Most of the time I see that error its a communication issue between the device and CPPM
    couple things to check
    1. url
    2. firewall/Role settings
  • 7.  RE: Issue with onboarding Android device
    Posted Nov 12, 2013 10:00 PM
    Troy,
    I was using landing.php in my URL. Once I took it out, it worked like a charm.
    Thank you very much for your help.
