Issue with VIA in route mode. NAT works fine. Any suggestions?
  • 1.  Issue with VIA in route mode. NAT works fine. Any suggestions?
    Posted Jun 21, 2012 08:04 AM
    I have VIA working fine in NAT mode.  When remove source nat from the interface and remove the SRC-NAT rule from the default-via-role I can't get traffic to/from the client machine.
    If any of you have this working and wouldn't mind sharing that part of your config, I'd really appreciate it.
    Robert
  • 2.  RE: Issue with VIA in route mode. NAT works fine. Any suggestions?
    Posted Jun 21, 2012 08:07 AM
    The only way it will work in route mode is if your VPN pool that you put clients into is on a subnet that is currently on the controller.  If your controller has a VLAN that has an ip address like:
    192.168.1.1 /24 , you would need to have your VPN pool like this 192.168.1.10 - 192.168.1.50.
    When you do that, the clients get a fully routable address that can be reached by your infrastructure, without requiring nat
