Hi Thanks for the response, Although looks like its on a diffrent line, i entered it on the terminal on one line, output below.
admin-ap@ub12:~$ sudo apt-get install python-software-properties ubuntu-cloud-keyring
[sudo] password for admin-ap:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies.
python-software-properties : Depends: python-pycurl but it is not installable
E: Unable to correct problems, you have held broken packages.
admin-ap@ub12:~$
I check the version to confirm
admin-ap@ub12:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 12.04.5 LTS
Release: 12.04
Codename: precise
admin-ap@ub12:~$
So i tried to fix the problem
root@ub12:/home/admin-ap# apt-get install python-pycurl
Package python-pycurl is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'python-pycurl' has no installation candidate
Tried an alternitive package
root@ub12:/home/admin-ap# sudo apt-get install software-properties-common
The following NEW packages will be installed
0 to upgrade, 1 to newly install, 0 to remove and 44 not to upgrade.
Setting up software-properties-common (0.82.7.7) ...
root@ub12:/home/admin-ap# sudo apt-get install ubuntu-cloud-keyring
Processing ubuntu-cloud.archive.canonical.com removal keyring
OK
root@ub12:/home/admin-ap# dpkg -i hp-sdn-ctl_2.4.3.0595_amd64.deb
Selecting previously unselected package hp-sdn-ctl.
(Reading database ... 52348 files and directories currently installed.)
Unpacking hp-sdn-ctl (from hp-sdn-ctl_2.4.3.0595_amd64.deb) ...
Creating system group 'sdn'...
...done.
Creating system user 'sdn'...
...done.
Creating system user 'sdnadmin'...
...done.
dpkg: dependency problems prevent configuration of hp-sdn-ctl:
hp-sdn-ctl depends on openjdk-7-jre-headless (>= 7u41); however:
Package openjdk-7-jre-headless is not installed.
hp-sdn-ctl depends on openjdk-7-jre-headless (<< 8); however:
hp-sdn-ctl depends on libpq5; however:
Package libpq5 is not installed.
hp-sdn-ctl depends on postgresql (>= 9.1); however:
Package postgresql is not installed.
hp-sdn-ctl depends on postgresql-client (>= 9.1); however:
Package postgresql-client is not installed.
hp-sdn-ctl depends on postgresql-client-common; however:
Package postgresql-client-common is not installed.
hp-sdn-ctl depends on postgresql-common; however:
Package postgresql-common is not installed.
hp-sdn-ctl depends on unzip; however:
Package unzip is not installed.
hp-sdn-ctl depends on arping; however:
Package arping is not installed.
hp-sdn-ctl depends on ntp; however:
Package ntp is not installed.
dpkg: error processing hp-sdn-ctl (--install):
dependency problems - leaving unconfigured
Processing triggers for ureadahead ...
Errors were encountered while processing:
hp-sdn-ctl
root@ub12:/home/admin-ap# sudo apt-get install software-properties-common python-software-properties
software-properties-common is already the newest version.
You might want to run 'apt-get -f install' to correct these:
hp-sdn-ctl : Depends: openjdk-7-jre-headless (>= 7u41) but it is not going to be installed
Depends: openjdk-7-jre-headless (< 8) but it is not going to be installed
Depends: libpq5 but it is not going to be installed
Depends: postgresql (>= 9.1) but it is not going to be installed
Depends: postgresql-client (>= 9.1)
Depends: postgresql-client-common but it is not going to be installed
Depends: postgresql-common but it is not going to be installed
Depends: unzip but it is not going to be installed
Depends: arping but it is not installable
Depends: ntp but it is not going to be installed
python-software-properties : Depends: unattended-upgrades but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
root@ub12:/home/admin-ap# apt-get -f install
Setting up unzip (6.0-4ubuntu2) ...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
