last person joined: 11 hours ago
Issues regarding CPP Guest Access and IAP securelogin.arubanetworks.com revoked cert
  • 1.  Issues regarding CPP Guest Access and IAP securelogin.arubanetworks.com revoked cert
    Posted Sep 29, 2016 07:37 PM
    Hi everyone!
    I’m facing an issue regarding to the recent securelogin revoked certificate.
    I had followed the Arubas’s recommendation and I have now a public wildcard certificate. I installed the certificate on the Virtual Controller for captive portal. On Clearpass, web login configuration, I replaced securelogin.arubanetworks.com with something.company.com –“*  Address: ” field. My cert is *.company.com.
    Guest users associate to the SSID and then they are redirected to clearpass login form. They validate their credentials and then redirected to https://something.company.com/cgi-bin/login. Any kind of browser says:
    something.company.com’s server DNS address could not be found.
    DNS_PROBE_FINISHED_NXDOMAIN
    And then no access to the network.
    Before Aruba’s certificate revoked, doing a nslookup to securelogin.arubanetworks.com returns an address 172.31.98.1, that points do the virtual controller.
    I’m confused… how to get guest users connected with clearpass and a public wildcard certificate? There is any cookbook? I spent several hours googling and nothing comes up.
    Thanks and best regards,
    JM
  • 2.  RE: Issues regarding CPP Guest Access and IAP securelogin.arubanetworks.com revoked cert
  • 3.  RE: Issues regarding CPP Guest Access and IAP securelogin.arubanetworks.com revoked cert
    Posted Sep 29, 2016 11:02 PM
    @Joao Martins wrote:
    Hi everyone!
    JM
    tl;dr
    Wildcard Certificates are supported starting in Instant 6.5.0.0-4.3.0.0 Early Deployment code.
  • 4.  RE: Issues regarding CPP Guest Access and IAP securelogin.arubanetworks.com revoked cert
    Posted Oct 24, 2016 06:27 PM
    Hi!
    Thanks everubody, indeed version 6.5.0 solved the issue.
    Everything working well as expected.
    Thanks!
    JM
  • 5.  RE: Issues regarding CPP Guest Access and IAP securelogin.arubanetworks.com revoked cert
    Posted Feb 02, 2017 07:19 AM
    Hi.
    I am having the exact same issue that you had. The virtual controller does not intercept DNS traffic to server.somecompany.com (that I have changed the value to in Clearpass).
    I am also running 6.5.0.0-4.3.0.0.
    After you installed the *-cert in the virtual controller did you do anything else? Restart all APs for instance?
    Best regards,
    Petter Miller
  • 6.  RE: Issues regarding CPP Guest Access and IAP securelogin.arubanetworks.com revoked cert
    Posted Feb 02, 2017 07:51 PM
    Hi Petter.
    Please check something like this on Clearpass Guest Management:
    You must always use captiveportal-login.your.domain. I recomend you install the cert also on ClearPass (no big deal, it´s a *.cert), not mandatory for this case.
    If you accomplish this, I believe you have solved the issue.
    Let us know if you have been successful.
    Best regards,
    Joao Martins
  • 7.  RE: Issues regarding CPP Guest Access and IAP securelogin.arubanetworks.com revoked cert
    Posted Feb 03, 2017 01:28 AM
    Hi Joao.
    captiveportal-login.your.domain resolved the issue. It now resolves captiveportal-login.your.domain to the internal VC address 172.31.98.1 which is correct.
    I had already installed the *-cert on both the virtual controller and on Clearpass. Everything seems to be working fine now.
    Thanks for helping out.
    Best regards,
    Petter
