Issues updating Clearpass HTTPS cert
  • 1.  Issues updating Clearpass HTTPS cert
    Posted Nov 08, 2017 09:13 AM
    Looking for possible things to check as Im scratching my head with this a bit.
    We have bought a server cert which I have chained in the order root->Intermediate->server cert
    I have checked the the 'Begin Certificate' and 'End certificate' statements are correct
    Whenever I try to import the certificate and key, I get the following message
    Failed to convert certificate to X509 PEM format. Accepted formats are .pem, .cer, .crt, .der, .p7b
    It is in .crt format so what are the other causes that could be causing the issue?
  • 2.  RE: Issues updating Clearpass HTTPS cert
    MVP EXPERT
    Posted Nov 08, 2017 09:25 AM
    Hey, try uploading the individual Root + Intermediate certs first (don't forget to enable them as well!) then upload the certificate (on its own) afterwards.
    If you have issues converting the cert, try the below:
    https://www.sslshopper.com/ssl-converter.html
  • 3.  RE: Issues updating Clearpass HTTPS cert
    Posted Nov 08, 2017 11:03 AM
    Im guessing that both the intermediate and root certs go in the 'Trust' section?
    Im trying to remember why we started chaining our certs, I think it was an IOS issue at the time, I will have to look back...
  • 4.  RE: Issues updating Clearpass HTTPS cert
    Posted Nov 08, 2017 07:09 PM
    You should ALWAYS chain your certs.
  • 5.  RE: Issues updating Clearpass HTTPS cert
    Posted Nov 10, 2017 04:01 AM
    OK I have re-chained the cert in Vi, and I have now added it via the GUI.
    I get no error message, if fact I get a 'success' confirmation at the top of the screen.
    But when I refresh the page the new chained cert is not applied, and I can't see any of the new cert details in the trust list either...
  • 6.  RE: Issues updating Clearpass HTTPS cert
    Posted Nov 20, 2017 10:12 AM
    Did you try it with the .pem extension? I usually chain CRT files to a pem for clearpass. (same process: just copy paste in notepad)
