Wired Intelligent Edge
last person joined: 8 hours ago
Issues with client device and JL658A 24SFP+ switch
  • 1.  Issues with client device and JL658A 24SFP+ switch
    MVP EXPERT
    Posted 11 days ago
    Testinig some cert/mac auth on a 6300 sfp+port switch with copper SFP+modules..... problem is,  1st time  (when i was watching ) the technician plugged a windows client it, it doid a machine based auth, downloaded a DUR, was dropped into the statically assigned vlan and obtained an ip address ..... great! seemed to work.
    Now  when you look at the switch interface, thers no link light on the port or the client machine. plug it into another switch ... works, plug it i to this one ... comes up then goes down.
    Is ther something etra i need to do for an SFP+ switch  with  copper GBIC?
    All ive got in  the DUR is
    Class statements allowing  DHCP,DNS,ICMP and an "allow all" ACL
    Policy using above
    Then
    associate policy staticvlS1h
    reauth-period 3600
    auth-mode client-mode
    client-inactivity timeout none
    Authentication uses statically assigned  swithc port vlan
    A
